Probably a simple rocker question...
Ok, good point, but it does seem to have a pointy tag that's not illustrated in the lousy pic.
I will go through every thing though. Thanks!
What's the reason for the weld, there's a blob on every rocker. On the pushrods side.
Craig
Culprit is not the weld but either you have a short stemmed valve or the rocker arm at the valve stem has excess wear. I've seen both be a problem.
Jerry
Hi,
I am working on a friends '58 and found that the intake rocker is tapping the inside of the cover. I believe that I heard that this is common. The rocker itself has a touch of weld (pushrods end) that seems to be the culprit. Two questions, what would be the reason for the weld and is the solution to just take this down some?
Thanks,
Craig
image.jpgTags: None
