Early Tour Pac Help
  • rbenash
    • Jul 2001
    • 643
    Early Tour Pac Help
    Hello - can't believe it but I have an NOS Tour Pac from 1966 all new in the box that I purchased years ago.
    I know I probably pulled the install doc and kept it "somewhere safe" but just can't seem to find it right now.
    I want to do the install ASAP but would like to have the instructions as they had a template for drilling the holes on the bottom to mount the spring brackets.
    rubone, or someone who might have a copy of the install guide - can you post up or pm me with a scan??
    Ray #7140
    Ray
    AMCA #7140
    • 2044
    digital transfer of template doesn't work
    • hennigan62
      • Sep 2010
      • 140
      You have a fax number ? I can get mine out when i get home tonight and fax in morning.
        • 1676
        something like this is what he's hoping for? (...this is NOT for the Tour Pac however!)
        • rbenash
          • Jul 2001
          • 643
          Thanks for your response but looking for tour pac (mounts on the rear rack) not saddle bags.
          Ray
          AMCA #7140
          • rbenash
            • Jul 2001
            • 643
            Yep - just turned it on.
            6108534762 - Thanks!!
            Ray
            Ray
            AMCA #7140
            • rbenash
              • Jul 2001
              • 643
              Hi Hennigan62 - not sure if you tried or not yesterday? FAX is still enabled, PM me if you are having trouble.
              Ray
              Ray
              Ray
              AMCA #7140
              • rbenash
                • Jul 2001
                • 643
                I will keep a copy of these templates in the library, so thanks for sending regardless.
                Ray
                Ray
                AMCA #7140
                • rbenash
                  • Jul 2001
                  • 643
                  duffeycycles:
                  PM sent - do you have a digital file? I'll PM you. You should be able to attach it to an email direct to me rather than trying to post it up here.
                  Ray
                  Ray
                  AMCA #7140
                  • rbenash
                    • Jul 2001
                    • 643
                    Hey duffeycycles! Thanks for trying. I just sent you a PM. Try sending as an attachment direct to my email address. I would really like a copy.
                    rbenash@verizon.net
                    I'll figure out how to get it posted up here for reference.
                    Ray
                    AMCA #7140
                    • rbenash
                      • Jul 2001
                      • 643
                      Hi hennigann62: FAX is on an ready when you get a chance to send today :-)
                      Ray
                      Ray
                      AMCA #7140
                      • hennigan62
                        • Sep 2010
                        • 140
                        Dug them out this morning. I'll stop by work and fax. Sorry for delay
                        • rbenash
                          • Jul 2001
                          • 643
                          Another twist is that the NOS brackets seem short for my rack, so I'm thinking the hardware might be for another model like sportster, etc.
                          I have extra brackets so good on that front. Templates will be helful so I can get the brackets mounted. I do have an older original that was
                          on the bike up in the loft. I'll dig that out in the meantime to adapt.
                          Still copies of the install sheets would be great to have. Can't beleive I can't locate mine. I know I pulled them from the box years ago to
                          keep in a "safe place". Gotta be around somewhere :-)
                          Thanks in adavance to all who are trying to help!
                          Ray
                          Ray
                          AMCA #7140
                          • rbenash
                            • Jul 2001
                            • 643
                            No apology required!
                            I'll scan them once received and post up here as a followup.
                            Ray
                            Ray
                            AMCA #7140
                            • rbenash
                              • Jul 2001
                              • 643
                              Got you now. There really aren't any templates for drilling as it turns out. But get what you were trying say now.
                              Apologies - I thought you were trying to transfer a file :-)
                              My bad. Thanks for the heads up though, totally get that.
                              Instructions sheets give you other visuals though that are helpful to figure out where things go.
                              Ray
                              Ray
                              AMCA #7140
