Tombstone Speedometer
  • Wayne Mehis
    Old School
    • Jun 2010
    • 22
    Hi Anyone interested in trading a good 2:1 Harley Tombstone speedometer for a 1:1 ratio I don't know how to post pictures on this sight yet but I'm sure I can do it on an email
  • harleycats
    • Mar 2016
    • 28
    Which ratio fits what
    • upsrod
      • Feb 2010
      • 320
      I am thinking a 2:1 Tombstone speedo would be aftermarket!
      • Wayne Mehis
        Old School
        • Jun 2010
        • 22
        Thanks for the feedback The speedo has the Harley logo on the bottom but yet I'm doing 90mph before I;m out of 3rd gear I know the correct ratio should be May have to bitr the bullet and get another one
        • vph-d
          • 1088
          You probably have a factory Eagle Iron speedo. IIRC, they were [are?] available in both 1:1 and 2:1 ratio.
          VPH-D
          • Wayne Mehis
            Old School
            • Jun 2010
            • 22
            VPH-D
            Thanks for the responce I believe you may have solved the mystery It has a painted 540 G 26 on it If that means anything
            • vph-d
              • 1088
              The code you describe is from a real H-D speedo, not an Eagle Iron speedo. I don't have access to my Stewart Warner [the maker] codes at the moment, but I'm sure someone will ID the speedo for you.
              VPH-D
              • upsrod
                • Feb 2010
                • 320
                That is the correct code, maybe wrong trans or trans speedo gears.
                • cdndewey
                  • Jan 2005
                  • 438
                  Here's a link to some speedo number info....
                  • Wayne Mehis
                    Old School
                    • Jun 2010
                    • 22
                    Thanks to everyone for the information The trans is correct (65) Will get this figured out yet Thanks again
                    • vph-d
                      • 1088
                      If you have a 65, the Tombstone face 1:1 speedo is the one you need.
                      VPH-D
                      • Wayne Mehis
                        Old School
                        • Jun 2010
                        • 22
                        VPH-D
                        I concur Thats whats got me puzzled as everything points to me having the correct speedo head
                        • vph-d
                          • 1088
                          So you're saying you have the correct speedo for your bike, but it reads about double?
                          VPH-D
                          • Wayne Mehis
                            Old School
                            • Jun 2010
                            • 22
                            Yes The only thing I did'nt eyeball was the drive gear
                            • vph-d
                              • 1088
                              Either the gear on the countershaft, or the driven gear that pushes down into the trans case is wrong. Most likely the driven gear is the culprit. Pull it out, and count the teeth.
                              VPH-D
