Starting problems
  • JosephJoe
    • Sep 2011
    • 36
    Starting problems
    Gentleman,
    My '59 Panhead Duo- Glide only starts when I take the aircleaner off.
    When the motor is warm she starts normal.
    Any idea, what could be the reason.
    Joe
    • 8247
    Golly Joe,
    The first obvious question would be: Do you have a copper mesh air filter as OEM, or perhaps a restrictive modern paper production?
    Of course, there may be other variables... too many to list easily.
    • JosephJoe
      • Sep 2011
      • 36
      I have a copper mesh air filter as OEM.
      Joe
      • harleytoprock
        • Apr 2003
        • 374
        A cold bike that has low battery voltage is very fussy about the fuel richness to start up. A little too rich or a little lean and it won't start because of weak spark caused by the low battery voltage. See if you battery is putting out 6.5 volts.
        • JosephJoe
          • Sep 2011
          • 36
          The battery is six months old and in good condition, but I'll check the output.
          Joe
          • JosephJoe
            • Sep 2011
            • 36
            The battery output is 6.3 volts.
            Joe
            • JosephJoe
              • Sep 2011
              • 36
              Come on Gentlemen,
              I hope this thread hasn't the same hard starting problems as my Panhead.
              Thanks in advance,
              Joe
              • Lyle Manheimer
                • Mar 2008
                • 193
                Joe, I have had my '64 FL for about 10 years. It is totally stock except for a modern paper air filter element. Yes dual points as well. I can not help but wonder if you have just not figured the starting drill out yet. When cold mine takes two prime kicks with the choke full on.Turn the ignition on, then choke comes completely off, I retard the ignition just a smidge and kick it through while twisting the throttle and more often than not it lights off. This works for me. These things seem to all have a slightly different procedure. If you are removing the air filter to start it, that tells me it ain't getting enough air. Are you sure you are not flooding it?
                • Lyle Manheimer
                  • Mar 2008
                  • 193
                  Joe, I forgot to mention on the prime kicks throttle needs to be wide open with the choke full on. You have to get that fuel charge into the cylinders.
                  • JosephJoe
                    • Sep 2011
                    • 36
                    Hi Lyle,
                    Thanks for your reply.
                    Maybe I'm flooding it.
                    Mostly I give it five prime kicks with choke full on.
                    Turn ignition on and set choke half, retard the ignition full, and the throttle 1/4 open.
                    Most of the time she won't start.
                    Joe
                      • 8247
                      Joe!
                      Five full choke kicks is a lot.
                      In warm weather, it shouldn't take but one, if that.
                      And then open the choke fully before the 'hot kick'.
                      But still, it always starts easy with the aircleaner off?
                      The choke rod is "Z"-shaped at the ends; Please inspect to see that it doesn't have such a long section after the carb shaft that the aircleaner backing plate prevents it from fully closing.
                      (After all, a great many were made from coat hangars!)
                      • Lyle Manheimer
                        • Mar 2008
                        • 193
                        Joe,
                        I think you are flooding it. Tom is right, five kicks with the choke full on is way to many. That is why you are removing the air cleaner to get it to start. If I flood mine I kick it with the throttle wide open and it will start after about six kicks. Throttle wide open gives it lots of air, removing the air cleaner gives it more air as well. Your issue is your starting drill.
                          • 2044
                          The Vtwin choke rods should be replaced with a coathanger
                          • JosephJoe
                            • Sep 2011
                            • 36
                            Lyle, Tom,
                            This weekend I'll try on my starting drill.
                            Joe
                              • 8247
                              Joe!
                              Everybody's bike and foot is different,
                              But assuming timing and all other adjustments are in order, my universal 'drill' for a cold motor in temperate weather is:
                              Key off, petcock open, spark retarded usually half-way, choke closed, one good kick, choke opened, pedal felt for compression, throttle just "cracked", key on, and boot.
                              Advance spark as soon as she 'lights up'.
                              In perfect tune, it will idle with a 'lope' until advancing the spark will pick it up to where it smooths out to a lively idle;
                              A warm motor should just need the retard, the key on, and a boot, then the advance of course....
                              Let us know how it goes,
