removing paint from engine
  • sailfish
    • Sep 2010
    • 175
    I just bought a 1957 pan that was rebuilt and the hole bottom end was painted wrinkle black is there any way to remove the paint with out taking the moter apart
  • vph-d
    • 1088
    You might try something like Easy Off oven cleaner.
    VPH-D
      • 5954
      Easy Off works well. warm engine make it work better. Set it in the hot sun.
      • sailfish
        • Sep 2010
        • 175
        Thanks for the help will try easy off thanks agin
        • oldsouthmcy
          • Jan 2009
          • 51
          Easy-Off works well on chrome exhaust pipes. However I would not use it on aluminum crankcases. Where aluminum is concerned, it is highly corrosive. The chances of it etching the cases are likely as the paint dissolves.
          Check this post from HD Forums
          Detailing - Oven Cleaner on Aluminum, MY WORST NIGHTMARE!! - ok so I pick up my new bike that I bought from a guy. Well he desided to put too much oil in it. Was riding home and noticed the ridght side of the bike and myself was covered in oil. Well the oil cooked on the exhaust, and I couldn't get it off. Plus he...
          Fabes does resolve the etching from the oven cleaner by polishing his cases, but polishing is not a good resolution for original panhead cases.
          Bruce Palmer III
          AMCA #667
          How to Restore Your Harley-Davidson
          How to Restore Your Military Harley-Davidson
          • TRADEMARK
            • Nov 2011
            • 67
            I just did a 1952 Panhead motor that was painted. Used orange sented Homer Formby's paint remover. Bought at WalMart? Let it set for maybe 10-15 minutes and then used a soft brass wire brush to get at the tough spots. Washes up with soap and water. Worked pretty well. Had to do some detail picking with a sharpened dowl rod.
            Tony
