Rigid Frame Trailer Hitch
  • dommi7
    I posted this to Knuckle and Pan forums - sorry to duplicate, but it fits both areas and hopefully I'll find some advice:
    I need a trailer hitch for my knucklehead and don't want to "re-invent the wheel" . Has anyone made or used a hitch on a rigid-framed bike?
    To elaborate:
    How was the hitch attached?
    Were any problems encountered?
    What would you do different next time?
    Any and all input appreciated!
  • pan64
    Not much help for a stock rear fender but I bolt this behind the axle with 3/4 inch bolts, chains attached to the sissy bar support the tounge weight.
    • dommi7
      Thanks for the shot - Its not too far from what I envision - I'll probably run a strap up to the saddlebag mounts to support the tongue weight.
        I used to pull a small trailer with my Panhead and just wanted to add to a note to upgrade your brakes, it's dangerous enough to ride among the idiots on four wheels let alone pulling a trailer with an antique bike with minimal brakes. Note the picture above and the disc brakes!
        Louie
