Hydraglide fork rebuild help needed
  • jeffrro1
    • Dec 2008
    • 47
    I need to rebuild a set of Hydraglide front forks for my 1953 Panhead. I have a sunnen hone to size the bushings but the problem I am having is removing the bushings. I wanted to do them myself if possible. Does anyone have a puller they might want to part with or recommend a puller that might work.
    I could also use the driver set up to install the bushings. I figured worse case scenario I could build some installers/drivers. Any help would be appreciated.
    Jeff
    Lakewood CO
