M74B Float Lever Pin
  • xofrevlis
    • Mar 2011
    • 23
    I am assembling a Linkert M74 B. While adjusting the float level it occurred to me that the float lever pin p/n 27383-11 did not have a means to prevent leakage. Is this part supposed to have a fiber washer or o-ring under the head? Any help or suggestions are appreciated.
    Thanks Wayne
    • 8247
    Wayne!
    A seal was never spec'd there, because it is supposed to be above the fuel level, believe it or not.
    (That's why sidevalves never had a bowl gasket either.)
    Beware any seal will increase the side-slop of the floatlever, increasing the chance of a "hang-up", often leading to hammermarks on the outside of the bowl.
    I cut very thin paper seals, but usually only use them when there is apparent damage to the sealing surface.
    • xofrevlis
      • Mar 2011
      • 23
      Cotton:
      Thanks for the advice. I will take appropriate action if I have a leak.
      Thanks Wayne
