Pushrod Lower Gasket leaks oil
  • 58Panheadfan
    • Dec 2006
    • 33
    Hello All
    I have a 58DuoGlide with some oil leak on lower Pushrod Gasket (Cork) at rear inlet. All others are dry. Isn't that much, but still leaking some oil. Running with Jims Powerglide Hydros...
    What I have done/installed, yet:
    - Changed gaskets 4 times 2x NOS Cork Gaskets (with & w/o sealer), 2 x Repro Cork Gaskets (with & w/o sealer)
    - Replaced everything thru NOS Parts (upper pushrod cover, spring, upper corks, washer, lower pushrod cover) except clip (I have one in order)
    - Lip on lower pushrod cover is flawless
    - Original Pushrod
    - have turned Pushrod Cover while riding in different positions
    I am at my wit's end - any refs are much appreciated, thank you!
  • BigLakeBob
    • 2768
    Try adding another washer, part #6762.
    Bob Rice #6738
    • 48hdbob1
      • Nov 2009
      • 111
      The top of the lifter is hitting the cork. Try doubling the lifter block gasket. I've had this a couple times with the Jim's lifters. You can also cut some from the top of the lifter but extremely hard steel and there is a snap ring groove to be aware of near the top of the bore.-Bob
      • 58Panheadfan
        • Dec 2006
        • 33
        Thanks a lot for your inputs... much appreciated. I will try doubling the lifter block gasket as suggested. Also thinking about to enlarge bore of cork gasket to avoid lifter hitting the cork...
        • 48hdbob1
          • Nov 2009
          • 111
          Don't know that I'd try that one. The lifter can be dis-assembled and some trimmed from the top of the lifter body for a permanent fix. Like I say very hard steel and a groove for an inside snap ring that holds the guts of the lifter in the bore, be careful.-Bob
          • 58Panheadfan
            • Dec 2006
            • 33
            Bob, ok I see... would be the best resolution for a permanent fix to trimm some from the top. I will do that work upcoming winter... thanks again!
