54 Pan Belly #s
  • Breeze427
    • Jan 2015
    • 4
    54 Pan Belly #s
    Unable To See The Belly #s Motor Is In The Frame, There Is A #7 Stamped On Each Case Would It Be Safe To Assume The Cases Match. Thanks
    • 4784
    No. The 7 represents a build type, and has nothing to do with them matching. The only way to know is by the belly numbers. You could have cases many years apart and have sevens on both....
    • vph-d
      • 1088
      The 7 means you have a 1200 cc FL engine, rather than an EL 1000 cc engine.
      VPH-D
