63 cases
  • nmaineron
    • Apr 2015
    • 15
    63 cases
    What do you see here,any issues...Thanks, Ron
    http://www.ebay.com/itm/301603486195...%3AMEBIDX%3AIT
    • 2024
    I don't see anything wrong with them that he did not declare in his description. Jerry
    • nmaineron
      • Apr 2015
      • 15
      Thanks Jerry,I see that they have been worked on for possibly a stroker and I noticed the the top end drain holes are coming into the skirt of the cylinder bore...what are your thoughts there...overbore???
        • 2024
        I do not see any work on them that would scare me. Lucklily they haven't been modified for big bore cylinders - that usually takes out the right case. Jerry
        • nmaineron
          • Apr 2015
          • 15
          Thanks,I put a bid on them....
          • nmaineron
            • Apr 2015
            • 15
            I got lucky and won the cases...
              • 2024
              Congratulations - hope we did not steer you wrong but I think they will work out great.
              • nmaineron
                • Apr 2015
                • 15
                I got my cases...all in all they are as was represented,I believe they have been setting for quite some time.I found a few things that weren't readily apparent at a glance.I pressed the cam bearing out and found a crack at 6 o'clock and another at the center bolt between the cylinders,minor but still a crack,and...a few teeth from a pump gear, I think, in the bottom of the galley in the muck that had accumulated... I think they are pretty solid. I have to fit a pinion race and do some minor welding and cleanup,I think they will work fine...
                • larry
                  • May 2009
                  • 247
                  Cracks are typically longer than they appear.
                  • nmaineron
                    • Apr 2015
                    • 15
                    Ya,pretty familiar with cracks...used to do non destructive testing on parts in the paper mill where I worked...
