Outside overhead oiling
  • JosephJoe
    • Sep 2011
    • 36
    Gentlemen,
    Is it recommended to use outside oiling heads in combination with '59 cases.
    And if so, what is the best way to make a conversion of the oil lines from inside oiling cases to outside oiling heads.
    Joe
    • 2024
    If it was my bike I would leave it alone and oil up the cylinder like OEM. Jerry
    • BigLakeBob
      • 2768
      I agree with Jerry, but I did do this for my '62. I was younger with few contacts and needed a set of heads and all I came across was an outside oiler set. I ran a line off my tappet screen. I made a custom fitting that duplicated the cap threads to a 1/8 pipe for a compression fitting. At first I used 1/4" line thinking more oil was better, wrong, too much oil that couldn't drain quick enough. I then used the same diameter as '63-'65, 1/8" I think and it was fine. I rode the bike with that setup for 10 years, never a problem.
      Bob Rice #6738
      • JosephJoe
        • Sep 2011
        • 36
        Thanks Bob and Jerry,
        I understand that the high temperature of the oil through the inside oil lines give a poorer lubrication.
        Are there any other considerations?
        Joe
        • larry
          • May 2009
          • 247
          The earlier oiling system will not be a problem.
          • BigLakeBob
            • 2768
            15 years of Panheads run fine with oil through the cylinders, I wouldn't alter unless for a different reason.
            Bob Rice #6738
            • nmaineron
              • Apr 2015
              • 15
              what about going the other way on 63-65 and opening up the inside oilers for earlier heads...
