I been having a hard time getting fuel to the plugs I have and m-74 carb on my 62 pan . I have fuel to the carb when I put the choke on and kick it over fuel will run out but none to the plugs. Stumped real bad can anybody helpThanks
fuel to the plugs
Sailfish!
The first diagnostic is always to search for a vacuum leak: http://virtualindian.org/11techleaktest.html
(Please test even the pan cover screws over each intake port, next to the top motormount studs, as occasionally they have been perforated.)
Common O-rings suffer badly in modern fuels, but now viton replacements are readily available.
PS: A motor should start even without getting the plugs "wet".Last edited by T. Cotten; 03-09-2015, 09:20 AM.AMCA #776
