1965 panhead FL
  • shovelhead
    • Nov 2010
    • 31
    1965 panhead FL
    Would like some info about the cylinders that are on my bike .The rear cylinder has a raised letter A 15-5 is this the right cylinder, the front has C 8-1 witch is also raised is this correct also for this year bike. Thank you Bill
    A 15-5 = January 15, 1965
    C 8-1 = March 8, could be 1961 or a replacement from 1971. Most likely a replacement.
    • vph-d
      • 1088
      More likely from 71, oiler barrels hadn't been invented in 61.
      VPH-D
        VPH-D
        And the finnage was different from '61, right?
        • upsrod
          • Feb 2010
          • 320
          '63-'65 fins are a little thicker, the easy way to tell with the motor assembled is the Motor Casting Co. logo on cylinders.
          • shovelhead
            • Nov 2010
            • 31
            Thank all of you for the answers Bill
