Rigid / swing arm rear rims
  • flthead
    • Dec 2003
    • 412
    Can a mechanical rigid rear wheel rim assembly be used on '58 or early swing arm juice brake pans ?
    • 4790
    Yes, the wheels interchange through '66, only the brake is different. There a re minor rim differences in the early '60s so you need to be sure of that if it is a restoration.
      • 2044
      And the hubs look slightly different-rigid vs swing arm-they will work as Robbie says
