1949 (only?) hubcap
  • Adam M
    • Feb 2013
    • 60
    1949 (only?) hubcap
    I was going over Bruce Palmers book, and noticed something I hadn't noticed before , under the 1949 equipment , a chrome hub cap was available and in parenthesis (solo or sidecar , 1949 style) in the photo it looks to have a cad plated spacer on the outside ? I don't have any photos to reference later years , style .
    I'd like to put a hubcap on my 51, and I don't believe there should or would be an access plug like the aftermarket ones have, and they of course have the spacer towards the inside . Any information would be greatly appreciated ...
    Adam
  • 49 pan
    • Dec 2013
    • 32
    Hi Adam
    I have a picture I could e-mail you but the hubcap is as you describe ,no hole and a cad piece that attaches to the hub-cap with 3-small screws.
    e-mail me if you like.
    Dick in Eustis
    • Adam M
      • Feb 2013
      • 60
      I really appreciate that Dick, I guess I'm going to have to check the factory accessory catalogs thru the years and try and pick up the changes . I sent you a PM with my email.
      Adam
      PS I found a part # in the 52 book of 43303-49 , so I wonder if the cap remained the same on the early hydraglides ?
      • 49 pan
        • Dec 2013
        • 32
        Hi Adam
        Did you receive the picture??
        I do have an extra cap but not the cad piece if it would help you.
        Dick in Eustis
        • Adam M
          • Feb 2013
          • 60
          I'd very much like to thank Dick for taking the time to help me with this, I came up with a hubcap that I believe is correct as the early glide accessory
          • jwl
            • Dec 2001
            • 338
            Adam
            IIRC 49 also used a rear hubcap in the deluxe solo option.
