Stainless Rocker Cover
  • BigLakeBob
    • 2768
    Was the stainless magnetic or not, or did HD use different types over the span of this cover? I have 5 stainless covers, one is non-magnetic and four are magnetic. Did a search and didn't see anything. Thanks for any insight.
    Bob Rice #6738
    Bob!
    The act of pressing and distorting the stainless imparts the magnetic affinity, or so I read on the web.
    It surprises me that you have one that is not!
      • 6039
      Bob, I checked the pans on my '51 with a very strong magnet, and they are non-magnetic. I've had this bike since the mid-80s and the covers looked old then. However, I would think the alloy could have varied by design from H-D engineers if they were looking for a cheaper, or easier to stamp cover.
      • cdndewey
        • Jan 2005
        • 438
        I need a pair for my 53 if you're interested in parting with a pair.
        • upsrod
          • Feb 2010
          • 320
          I too have one that is magnetic and one that is not...every other genuine H-D stainless part I have is magnetic, air cleaner covers, horn power pack cover, Hydra-Glide front and back panels and the cow bells.
          • vph-d
            • 1088
            From what I understand, some, or all SS is magnetic. Apparently is depends on the grade of the SS.
            VPH-D
            • HD48FL
              • Jan 2007
              • 138
              VPH-D
              300 series stainless is non magnetic.
                • 2044
                316L -pure stainless is not magnetic-most Stainless had iron added to make it malleable-pure stainless does not bend easily without cracking-were they molded and not bent? Bent hot?Most original stainless HD parts are attracted to magnet.Stainless sheet metal is often 304 stainless-not pure
                • HD48FL
                  • Jan 2007
                  • 138
                  16L is from the 300 series, the "L" is low carbon. 316L is highly corrosion resistant. That stuff is tough to machine as well.
                    • 2044
                    low carbon steel cutting speed= 90---316L =40[did a lot of that!]
                    • Runnlo
                      • May 2010
                      • 34
                      I have a 1948 EL that is original unrestored (winners circle bike)...sorry I can't keep from bragging on it. When I got it from the original owner, it had 1952 plates on it. Anyway it has SS non magnetic pans.
                      Enjoy your Labor Day to all.
                      Runnlo
                        There wrong. 48 had chrome plated steel. Bob L
                        • Runnlo
                          • May 2010
                          • 34
                          You wouldn't want to bet on that would you? If so then you name your own amount, I'll go as far as you want to go.
                          I just told you that I bought the bike from the original owner, and he only rode it for four years. I've owned it for 35 yrs. I'ts won every award it can win, and the pans have never been questioned. So now the question is....how much are you willing to lose. I'll be waiting.
                          • BigLakeBob
                            • 2768
                            Thanks for everyone's responses. I was hoping for a cut and dried answer, but it seems like maybe HD went with either material depending on vendor or what was cheapest at the time? Maybe they started off non-magnetic then switched? I think I am opting to go with the non-magnetic.
                            UPSROD, do you want to trade your non for a magnetic one, sell or other trade for something you need? Assuming the two you have are not on a bike.
                            CDNDEWEY, let's see how things turn out and maybe we can do some trading, do you want the non or the magnetic type?
                            Bob Rice #6738
                              Here's a little more cut to dry, Bob...
                              On the left is a piece of stainless sheet that has no detectable affinity for the speaker magnet next to it.
                              Hanging upon the magnet is a piece of the same sheet that has been pressed upon a doming block.
                              The mystery is why some covers are not magnetic. (All of mine are.)
                              PS: Yes, they are near vertical in the photo.
