Transmission gears
  • Transmission gears
    Hi guys,
    The '49 to 57 spare parts book list 2 separate low gears for the transmission. One being 35282-36 and then a 35286-39 which is listed as being for hand shift. Same deal with second gear.
    What are the differences? Also wondering why the difference, I can see a need for different gearing for a 3 speed w/ reverse, but not sure why hand shift would need to be different?
    Craig
    Craig
    1939 had a one year only shift pattern 1-2-N-3-4. That's the reason for the difference. The -39 gears that you are referring to are only for 1939.
    Mark
    Mark Masa
    www.linkcycles.com
      Ah that explains the hole in my knowledge, the fact that I doubt I will ever own a Knuckle, so I have never really learned a lot about them. Well, that and some timers disease. And beer. And selective hearing... Etc.
      Thank you for the answer!
      Craig
