Rear crash bars for 1965 flh won't fit (VTWIN)
  • Semper Fi
    • Feb 2014
    • 43
    I'm in the process of putting my 65 FLH back together and had bought VTWIN's rear crash bar set (pn 51-0928) and when I went to put them on, the shock stud is too small to screw into the threads on the crash bar. I do see that VTWIN sells a stud kit (pn 54-0409) that looks like it might be the solution, but nowhere do I find any supporting information that this is what I need to mount the crash bars. I searched the forum, but couldn't find any hits. I can't be the only one to run into this problem, can I? Need a little bit of help here, if you can.
    SF
  • koanes
    • Apr 2003
    • 656
    The 65's had 3/8-24 threads, 66-67 used 7/16-20. You will need to change the studs to make the crash bars fit.
    Kyle Oanes AMCA # 3046
    • Semper Fi
      • Feb 2014
      • 43
      Any idea where I can find this? The VTWIN 54-0409 shows the threads to be 5/8X18 and 1/2X20. I can't find anything online that has the 7/16X20 thread.
      SF
      • Semper Fi
        • Feb 2014
        • 43
        I did what I should have done first....mic'ed the crash bar and it turns out to be 1/2X20. This means the VTWIN 54-0409 and oem 54515-65 are the correct sizes. I have been told that the early 65's had the smaller outside threads and later in the model year was changed. Oh my, what a pleasure to restore this year.
        SF
        p.s. Found the best price at M&M Cycles in Ohio.
        • koanes
          • Apr 2003
          • 656
          Sorry Semper Fi. That is the second time I called it as the 7/16 size knowing full well it is 1/2. You would think after I was corrected the first time I'd remember. I looked for a long time to find a decent original set of bars for my 65.
          • Semper Fi
            • Feb 2014
            • 43
            Not a problem. Thanks for trying.
            SF
            • upsrod
              • Feb 2010
              • 320
              My '65, made Aug. 11 of 1964 has the 1/2 upper stud size.
              • Semper Fi
                • Feb 2014
                • 43
                Thanks, Rod. Mine must have been earlier because the stud is smaller.
                SF
                • Semper Fi
                  • Feb 2014
                  • 43
                  Still having problems.... got the newer studs from VTWIN and they are 1/2X20. The bars, also from VTWIN, won't accept the studs. I can't figure out what is going on. They seem to have a different pitch. I thought the bars had the 20 pitch, but they don't. HELP, please.
                  SF
                  • vph-d
                    • 1088
                    Can you fit a thread pitch gauge into threaded hole in the bars? No telling what V-Twin used for internal threads.
                    VPH-D
                    • Semper Fi
                      • Feb 2014
                      • 43
                      VPH-D
                      Yes, I'll try that today, but I would have thought that since both products were made by them, that they would be compatible with each other. Guess I was wrong!
                      SF
                      • billpedalino
                        • Mar 2005
                        • 1096
                        Maybe a Helicoil is the answer ?
                        Bill Pedalino
                        Huntington, New York
                        AMCA 6755
                        • Semper Fi
                          • Feb 2014
                          • 43
                          The problem has been solved. I chased the threads on the studs and the bars. Seems the chrome was enough to prevent the threading between the two. I tried this with a cheap set of Japanese taps and dies, but they weren't accurate enough to get the desired effect. I took them over to a buddy with a good set and that fixed it.
                          SF
                          • terry01
                            Pans-Kitchen:Shovels-Shed
                            • Sep 2013
                            • 20
                            Question... How can you tell the day your bike was made? I just acquired a '65 and am very curious.
                            • Semper Fi
                              • Feb 2014
                              • 43
                              I don't have any way of knowing that, I'm afraid.
                              SF
