Welding Tool Box Mount
  • billpedalino
    • Mar 2005
    • 1096
    I'm replacing the toolbox mount on a 1951 panhead frame and I need to know the correct bracket location along the top and bottom frame tubes. I can find the approximate horizontal location by installing the oil tank and positioning the tool box/bracket assembly, but the bracket's frame tube radii are quite loose and are not bent parallel to the tubes. Therefore, I'll have to position the bracket on the frame and re-shape the radii around the tubes before welding. Can anyone (Steve L ??) provide the correct location measurements for this bracket?
    Thanks...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • Steve Little
    • Apr 2008
    • 915
    Hi Bill.
    It might be best if you shoot me an email and That will prompt me to reply with some info. I struggle a bit with organization at the moment.
    The virus makes me a bit scatter brained....some of my old friends say nuthins changed. But that's my story and I,m stickin to it.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
