front brake cable replaced on 62 pan
  • sailfish
    • Sep 2010
    • 175
    Iam replaceing the front brake cable and brake tube the cable runs throw the adjustment screw only goes in the tube a little ways . How far should it go in the tube? and do I have to cut the screw? thanks for all the help
  • koanes
    • Apr 2003
    • 656
    The adjuster should go into the tube all the way with the adjuster lock nuts threaded all the way to the top.
    Kyle Oanes AMCA # 3046
    • sailfish
      • Sep 2010
      • 175
      thanks it is a tight fit
