1950 belly numbers
  • jstraker
    • Oct 2013
    • 59
    1950 belly numbers
    Hi, folks. This isn't really a technical question, but I could use a knowledge infusion if there is spare out there. I just picked up a 1950 FL - good case/VIN, no alterations, straight backs on the 6s, etc. Belly numbers are matching, and look like they should, stamped 1950. But...Palmer says the first digit of the belly number should designate the engine size, with an FL being a "1". Mine are marked "350-xxxx", which according to Palmer should be a 45". Any explanations out there?
    Thanks!
    Justin
  • BigLakeBob
    • 2768
    My '50EL is 150-xxxx. Bob#6738
    Bob Rice #6738
    • jstraker
      • Oct 2013
      • 59
      Thanks, Bob. Palmer says that a 61" OHV should be stamped with a 2! So I guess these "rules" don't always apply? Or are just wrong...?
      • HD48FL
        • Jan 2007
        • 138
        Check out post #18: http://www.caimag.com/forum/showthre...Numbers)/page2
        And another thread: http://www.hydra-glide.com/phpBB3/vi...numbers#p60167
        • jstraker
          • Oct 2013
          • 59
          Thanks, those were really helpful, 48. Looks like it all checks out.
          Cheers,
          Justin
