Duo Glide Wheel Rims
  • Duo Glide Wheel Rims
    Hello,
    For a late '62 Duo-Glide restoration, would a wheel rim with 43006-62 stamped into the rim be the correct rim?
    If not, what would be the correct rim part#? Pictures of the correct rim detail would be greatly appreciated.
    Thanks again for all the help!
    Maybe this link to a pic will work (I hope)
    This is the 43006-62 wheel rim I'd like to use for a late '62 Duo Glide restoration. Correct for late '62?
    [IMG] [/IMG]
      I beleive it is the right wheel. The edge is rolled over a littler further than the earlier ones. It still is not a safety beaded wheel.
        Thanks! This is really helpful - I can't thank you enough!
        I think I get it now. For a '62, the rim is rolled over to the outside more and NOT a safety bead.
        Thanks much,
        IRon
        p.s.
        Just curious; do you know what year the safety bead rim began to be used on Duo Glides?
