reproduction oil tank for panhead, opinions??
  • jackrabbitjack
    • Apr 2013
    • 5
    Has anyone had experience with the reproduction horseshoe oil tank? Such as fitment and quality.
    thanks for your advice.
    jack
    • 6039
    Just curious, why not use a genuine tank? They are usually reasonable in price. . . Unless I'm that out of touch
    • Kozy
      • Feb 2004
      • 129
      I tried a repro oil tank on a 47 U. After mounting, could not fit u bolts for coil between tank and seat post tube and had problems with the chain guard bracket, it had huge bolt hole drilled in it. An original for a pan should be easy to find, might even cost less than the repro and if you have to replace the chain guard bracket at least you'll have the opportunity to get it in the right location and drill the right sized bolt hole in it.
      • 36 knuck man
        • Dec 2009
        • 294
        Eric is right, the real ones are easy to find and under 100 dollars, thanks, Larry
        • jackrabbitjack
          • Apr 2013
          • 5
          thanks i got oem.
          • jackrabbitjack
            • Apr 2013
            • 5
            thanks got oem. jack
