Adjustable tripple tree identification.
  • jeffrro1
    • Dec 2008
    • 47
    I just bought a 53 panhead. This is my first Harley. In the reading that I have done it looks like there are two different adjustable triple trees for side car use. In the Palmer book it talks about a triple tree that is adjusted by washers. I ended up buying one but it only has one large bolt with a castle nut on the other end but does not have any washers. I am trying to figure out what I have and what I need to locate for sidecar use. Any help would be appreciated.
    Jeff Goorman
    • 2019
    Sounds like you have a triple tree from a servi-car that was not adjustable but was always locked in the raked position. It can be machined to be a sidecar tree.
    Jerry
    • Lonnie
      • Feb 2002
      • 591
      The adjustable trees used in the 1950 models used two bolts, the later ones used a single bolt. The washers you mention look like elongated washers with a post that extends down into a slotted hole on each side. When the bolt is loosened, the washer can be rotated 180-degrees and then put back into place into the slot. The posts helps secure it all so that the position of the bolt will not change.
      As Jerry notes, the ones used in the Servi-Cars were the same as the sidecar versions with one big difference - there is no slot, merely a hole so that there is no adjustment so there is no need for the washers.
      I bought a set of the Servi-Car trees cheap-cheap and a friend with a machine shop slotted the hole for me. I bought the washers from Old Dude. The bolt is the same. You can do the same.
      I've noticed on Ebay on more than one occasion that some folks will advertise a set of Servi-Car trees as adjustable; conveniently the photos won't have a clear shot of the bottom tree so you can't see that the hole is not slotted. Buyer beware.
      Lonnie Campbell #9908
      South Cackalackey, U.S. of A.
      • jeffrro1
        • Dec 2008
        • 47
        Lonnie
        Would you have any pictures of the machine work. I have never need an adjustable triple tree and don't quite know how the washers work and what machine work would have to be done.
        Jeff
        • camsaure
          • Nov 2009
          • 135
          How are the 1950 style trees construed? Simply two separate holes or what?
          • cdndewey
            • Jan 2005
            • 438
            They have one elongated hole. The position is determined by the placement of the above said washer. The bolt goes through the washer, lower trees and the washer again.
            • camsaure
              • Nov 2009
              • 135
              Sorry, but I thought the earliest ones didn't have a bolt going all the way through, but rather a bolt on each side. Was I wrong on this?
              • cdndewey
                • Jan 2005
                • 438
                No, you're correct. I screwed up...didn't read your post properly.
