Couple of questions in general on a kicker and trim
  • sknappy
    • Feb 2008
    • 33
    I have purchased a couple of bicycle kicker pedals one from JP cycles and another from a vendor at the Denver swap meet, neither one is worth a crap. Every time I start my bike the rubber twists and the hardware loosens. I was smart enought to keep my old kicker but it is so wore out that i'm affraid of completley destroying it. Does anyone know of where I can get some repair parts for it?
    Question 2, I need the hardware to hold the trim onto the front fender of my 62 pan, most of mine are good but a couple are getting bad to where they will soon be broke. I noticed the square tabs that slide down the trim are different sizes, but any ideas or info where I can get them would be helpfull. Trying the parts store today just by chance.
  • kg993
    • 263
    I don't know about a good pedal but if the nuts are still good on the trim pieces I cut off the studs and thread the plates, then make new studs from a good grade screw. Put them together and put a light tack weld on the back side, file or grind a little if needed.
    Kerry AMCA # 15911
    • kg993
      • 263
      Also some places sell, I think they're called Union Nuts. About a 2" long hex nut. They can be machined to look origional or just cut to size and used as is. But they may only come in course thread.
      Kerry AMCA # 15911
      • sknappy
        • Feb 2008
        • 33
        thanks I will try to see what I can come up with
        • Rollo
          • Nov 2008
          • 599
          I know Old Dude carries the trim studs and nuts.
          Tom (Rollo) Hardy
          AMCA # 12766
