gas line on 62 pan
  • sailfish
    • Sep 2010
    • 175
    gas line on 62 pan
    i just got a gas line for my pan the one that goes from the tank to the carb it has a loop on one end is that for the neck of the horn to go throw? I got the line from jp cycles they said for 57 to 65. Thanks for the help god knows i need it!!!
    • 2044
    The gas line crossover that goes tank to tank has loop but my books don,t show a loop in the feed to carbHere is the vtwin '50-65-some bending requiredIMG_1580.jpg
    • sailfish
      • Sep 2010
      • 175
      thanks that is what i thought
      • grollock
        • Feb 2013
        • 14
        Sounds like the line that connects the tanks.
        • nodakpan
          • Aug 2012
          • 6
          the photo Duffyscycles shows is the correct one for tank to carb. If you are talking about one w/a banjo fitting which is the crossover line between tanks, you should get the one w/out the loop, jp part # 720-023 or 023 chromed, not jp # 720-0781.
