Metal epoxy
  • white1j0
    • Feb 2012
    • 18
    Metal epoxy
    I broke a screw off of a front fender tip, which is lite ga.SS, too thin to tig, does anyone know a realy good metal epoxy, also i'm looking for the fuel tube fitting that screws down on the top of the tank, Thanks Whitey
    Whitey!
    I would suggest a more proper repair of cutting a flat-topped "screw", and silver-soldering it to the trim.
    It will require minor external polishing for heat discoloration, but worth the effort for a sturdy fastener.
