Need some advice on removing compensating sprocket on my 61 FLH. Engine was recently rebuilt however mechanic turned off primary oiler. Heard some knocking in the case after a few hundred miles. Primary chain was the color of rust(totally dry), extremely loose, and has a lot of lateral play. Needs to be replaced but the sprocket won't budge using all methods used previously. Any suggestions?
