54 Transmission Problem
  • snyder3244
    • Jul 2009
    • 28
    I just bought a 54 FLE with a ratchet top transmission/mouse trap. I am having trouble getting it to go through the gears. I litterally have to "kick" it through ( no grinding). Once it is in gear it runs fine. I adjusted the clutch but it didn't help. Any advise would be appreciated. Thank You.
    • 2025
    If the clutch is not disengaging all the way it can cause hard shifting from a stop. Once you are rolling it will work good. It usually will not go into neutral cleanly either once the bike is stopped. Jerry
    • snyder3244
      • Jul 2009
      • 28
      When it is not running it is very hard to impossible to shift. When it is moving it shifts but it is very hard.
