Panhead Police Bike -- Ex Sandanista/Nicaragua
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    I referenced this bike in another post. Saw it Friday and was in love.
    Today, I had the EL out for a ride and stopped back at Harbor Vintage where this bike is in for some work and re-commissioning. Apparently an original sidecar is also being fitted/refitted.
    I snapped some pictures. I don't know who the owner is, but he is one lucky guy!
    I have two more, but have to attach them in the next post.
    Cheers,
    Sirhr
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    Last two.
    I wonder... if your name got written down on the notepad, did you and your entire family disappear?
    This bike is an unbelieveable reference machine. It's just like new, under a little dust. The stories it must be able to tell.
    Cheers,
    Sirhr
    • BigLakeBob
      • 2768
      Beautiful bike, can someone educate me on the spark plug wires? Were they different not to interfer with police radio? Thanks, Bob AMCA#6738
      Bob Rice #6738
      • sirhrmechanic
        Vigilis
        • Dec 2010
        • 1147
        They would be shielded to prevent spark interference, also called EMP. It was part of a police radio package. Also was fitted on some WLA/WLN/WLC military bikes. From memory... but I recall from one of the restoration guides that there was a special manufacturers code that went with either the bike or the ignition systems when they had shielded components.
        Cheers,
        Sirhr
          • 4790
          There were various shielded cables over the years for radio equipped bikes. These are '40s type for use with the 18mm air cooled plugs.
          Robbie
            • 6039
            Robbie, what are the extra lugs on the coil for?
            • D.A.Bagin
              • Jan 2008
              • 595
              Speedo says 10 miles?
                • 4790
                They are grounded to the coil body and are used for radio noise suppression equipment. A condenser bolts on one with the other end connected to the hot post. The other connects to the shielded timer wire. Here is the wiring diagram which shows it!
                Robbie
                  • 6039
                  Thanks Robbie. It's interesting that so many condensers were used.
