Panhead Tool Box Mount
  • billpedalino
    • Mar 2005
    • 1096
    I'm replacing the tool box mount on a 1953 FL frame. I have an aftermarket bracket that looks pretty good as well as the approximate measurement of where, on the bottom frame tube the bracket is to be placed. My question is which joints get welded. I would assume that the bottom joint on the bottom of the lower frame tube (parellel to the ground) gets a full-lenght fillet weld, as well as as the vertical (side) returns running up and around the bottom tube. Is there also an 'inside' horizontal fillet weld placed on the TOP of the bottom tube between the tube and bracket?
    Thanks...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • Steve Little
    • Apr 2008
    • 915
    Hi Bill.
    Correct oem look is about 1" long electrode weld along the bottom from each edge of the bracket.
    On the top of the tube, weld from the outside edge of the bracket to about the same measurement.
    It is the width of each strengthening channel on the outside edge of the bracket. No welding in the centre depression of the bracket.
    If you have an arc welder with DC range, use that setting with a general purpose rod. The DC setting will give a flatter, more original looking weld.
    There is a measurement to observe on the original drawing, but you may find it easier to fit you'r original fender and toolbox and put the screw through the hole in the fender. Email me if you need more info or pictures.
    Hopefully you haven't got a Tiawan bracket. The holes are in the wrong position and they don't have the square nuts spot welded to the back.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • kg993
      • 263
      Good timing on these posts as I'm almost ready to fit the aftermarket mount on the 51. Fortunate enough to still have the top half of origional mount still intact. Considering only replacing the missing lower half because the rolled edges are not exact on new mount. Any comments on that idea.
      Kerry
      Kerry AMCA # 15911
      • Steve Little
        • Apr 2008
        • 915
        Kerry. I would be more inclined to remove the remanent of the old bracket and replace it with a good quality, complete bracket.
        Trying to get two halves of two different pressings to match up, is always going to be hard work. Even if you had two halves of two different genuine brackets
        My experience of few years ago....a customer sent me three different loose frame sections he had collected over the years with the instructions to marry it all up into a 1940 frame for a Knuckle he was restoring. The axle carriers still had the top tubes intact and the top section of the toolbox bracket with the riveted cross bar but the bottom section of the bracket was broken off and missing. We tried to retain the one year only 1940 toolbox bracket for the customer by using a original section of toolbox bracket from a wreck.
        It didn't work. We wasted hours and it had a slight step in the shape because of the different time it had been stamped.
        Steve Little
        Australia.
        AMCA member 1950
        • kg993
          • 263
          Thanks Steve, Is there a good quality bracket on the market?
          Kerry
          Kerry AMCA # 15911
          • billpedalino
            • Mar 2005
            • 1096
            Steve,
            If I understand your instruction, it looks like a 1" weld along the bottom and in the middle of the bracket, and a 1" verrtical weld along each vertical edge? If I'm wrong, can you post me a picture here or send it to my email address; WMP@soundindustries.us?
            I will most likely stick-weld the bracket using a 3/32" 7018 low-hydrogen rod. Its a clean weld and the bead size can be controlled.
            As for the quiality of the replacement bracket, it may be a Tiawan knock-off, as I bought it from Ted. But the stuff that he uses on his reproduction frames has, in my opinion been quite good. The bracket holes do line up with those in the tool box and it does have the spot-welded square nuts.
            Thanks for the information
            Bill
            Bill Pedalino
            AMCA 6755
            • Steve Little
              • Apr 2008
              • 915
              Hi Bill. I just tried to download some pictures for you but I think my office laptop is having some kind of coniption.
              If someone else can upload the pictures I can still email them.
              Bill, I would not recomend Low Hydrogen rods. They are great for hard surfacing grader blades, but with the hardness comes brittleness. The vibration of our favourite bikes will crack a low hydogen weld.
              I use 2.5mm general purpose rods when I weld up our frames....and I believe HD did as well.
              I Started full time frame manufacture and frame restoration in 1989 and no breakages yet.
              When you are ready to weld the bracket, set the frame so that you are welding slightly downhill and this will make you move faster during the weld.
              This will give the weld the correct appearance.
              The way you have described the weld placement does not sound right. I would wait until you see the pictures.
              Regards Steve
              Steve Little
              Australia.
              AMCA member 1950
              • cdndewey
                • Jan 2005
                • 438
                I'm interested in the pictures also Steve.
                • billpedalino
                  • Mar 2005
                  • 1096
                  Thanks for the advice Steve. A milder, softer steel would be more maliable and more elastic than the Lo-Hydrogen 7018 or even the celulose 6010 rod and definately less resistant to the cracking caused by fatigue failure that comes with vibration. As I'm now in the Marine Contracting Business, I automatically think of the materials that we use - sometimes not appropriate for motorcycle applications, as you well-noted. Great point and I certainly will follow your advice.
                  I'm curious about the full-time frame restoration that you perform. Can you provide your Company information for future reference?
                  I'm also looking foward to some pics of an OEM tool bracket installation - Anyone have a pic of the welds on the late (1953 - 1957) tool box bracket?
                  Bill Pedalino
                  Bill Pedalino
                  AMCA 6755
                  • Steve Little
                    • Apr 2008
                    • 915
                    Bill I will send you a personal messgage
                    Steve Little
                    Australia.
                    AMCA member 1950
                    • Steve Little
                      • Apr 2008
                      • 915
                      Hi.
                      I have pictures and plan drawing that will help everyone with the correct placement and welding of the 52-57 toolbox bracket.
                      When I try to load them (5 times) onto the web site, the little web site load wheel just keeps spinning around, and around and around and around until I loose patience and storm back into the workshop clenching my fists and mumbling, to work off the grumpiness.
                      Can anyone offer to accept a email and load them up.
                      I need to stop my workers giving me furtive sideways glances.
                      Steve Little
                      Australia.
                      AMCA member 1950
                      • NiteOwl
                        • Jun 2011
                        • 247
                        Originally posted by Steve Little View Post
                        Hi.
                        I would be more than happy to upload for you, I sent you a message.
                        Here they ARE:
                        Bob Beatty
                        AMCA 19209
                        • white1j0
                          • Feb 2012
                          • 18
                          Wasco makes a decent repop, about 46 bucks.
