Dust Ring (shield)
  • kg993
    • 263
    Dust Ring (shield)
    I've looked through the Palmer book and can't pin down what the finish should be for the dust ring and rear sprocket on the 51 FL. All I can find is the drum should be black. Maybe the whole assembly was painted after riviting together?
    Kerry
    Kerry AMCA # 15911
    Both the sprocket and dust ring are parkerized. Do yourself a favor when you do this. Get some #6 screws at Home-Puke and screw the whole thing together. Then rivet one hole at a time leaving the screws and nuts in the remaining holes. If you don't do this the dust ring deforms into a total mess. If ya got the option, power coat the drum in low gloss black. You will be forever happier. Bob L
      I once had a NOS brake drum assembly. The sprocket and shield were Parkerized and masked off when the rest of the drum had been black painted.
      • kg993
        • 263
        What took so long to reply? No seriously thanks.
        Kerry
        Kerry AMCA # 15911
