1958 duo glide frame identification
  • ernort
    • May 2011
    • 6
    add pici need some help identifying a 1958 duo glide frame, the frame is a step frame, has the 58 on the swing arm,duo glide servi stand, correct rear lights and tin,the motor mount has a 71 stamped, i do not see a A,B,C..8 stamped on the mount,where else can i look to determine the frame year?
    any help will be much appreciated.
    BTW this is the first time i post, so excuse me if pic does not show.
  • Hollywood
    • Mar 2011
    • 223
    7 is for 57 and I is for the 9th month September. So that would be a 58 production year frame. made in sept 57.
    • ernort
      • May 2011
      • 6
      is that the only place the 7I is stamped?
      thanks
        That's it in a nut shell.
        • ernort
          • May 2011
          • 6
          sounds good..i 'preciate your replies..
          58 it is..cool
