Correct transmission plate for a 58 FL
  • gotnoclass
    • Feb 2012
    • 19
    Can someone please post a picture of what a correct 58 tranny plate should look like? Palmer's book does not have any info..
    Any help would be appreciated! :-)
    Ron
  • 58panman
    Old Member
    • Dec 2010
    • 91
    Based on a book I have it indicates a 47698-58 is in order. If you Google that part number there is a forum discussion and some pics. Don't know if it will help, but worth a try.
    • vph-d
      • 1088
      The Dou Glide trans plate has wider spacing between the front mount holes than a rigid plate.
      VPH-D
      • gotnoclass
        • Feb 2012
        • 19
        Thanks 58panman and VPH-D. After reading the posts on the various sites, it still seems as folks are not 100% in agreement to what it should look like.. I guess as many opinions as there are tranny plates out there.. I am especially curious about the cutout or notch on the one side of the plate? Some plates have it and some do not?
          Enough all ready! There are to plates that you're going to run into for the most part. the ridged one and the 58 and up swing arm one. They are easy to tell apart. On the ridged one the front left side bolt to frame hole is off set to the right. On the 58 and up the rear holes line up with the front holes. The problem you're going to run into (The reason I would not buy one of these on Fleese-Bay) is starting in 1965 the factory no longer machined the indexing squares so your 64 and down tranny will not drop into it. You cannot tell by eye. You need a caliper in your hand to mic the squares. Good Ruk! Bob L
          The 57 and down is on the left and the 58 and up on the right.
          • gotnoclass
            • Feb 2012
            • 19
            thank you for clearing this up Bob :-)
