shock studs 62 pan
  • sailfish
    • Sep 2010
    • 175
    shock studs 62 pan
    are the shock studs on a 62 pan zinc or crome are the cups that cover the rubber gromit zinc or crome? Thants for the help
    • 4790
    Neither! The studs and the cupped washers for the rubbers are cadmium plated.
    Robbie
    • knuckcrazy
      • Feb 2010
      • 147
      Robbie
      Yup! I agree
      • upsrod
        • Feb 2010
        • 320
        I say they are both parkerized.
        • knuckcrazy
          • Feb 2010
          • 147
          Then I had better take my orig paint 62 out and get em done cause I would hate to be out of fashion.
          • koanes
            • Apr 2003
            • 656
            The studs on my original 60 were parkerized or blackened.. I cleaned them up and had them cad plated, then found info that that was incorrect. I don't know about 62.
            Kyle Oanes AMCA # 3046
            • upsrod
              • Feb 2010
              • 320
              My 62 had all four studs parkerized as well as the FLAT washers. My 65 had parkerized lower studs and cad upper studs. The cupped washers
              started in 65 and were cad. I think all four cad studs may have started in 66.....IMHO
                • 4790
                I think you are right on that Rod, trying to dig deeper in my mind I recall parkerized studs under the full top covers. So I'll retract my earlier comment until I can come up with definitive proof or an unmolested original shows up!
                Robbie
                  They were all Parkerized. The stud, washers and nut. Just compare them in this 63 pic from Chris to the lower shock parts that were cad. Bob L
                  • Panacea
                    • Dec 2011
                    • 36
                    The studs are parkerized on my 64...Mike
