problum with frame repair
  • sailfish
    • Sep 2010
    • 175
    i just had the speedo and back tank mounts welded on my frame the lower tabs are about a 1/2 inch above the lower tank mounts what should i do? also it looks like one
    tank is a little bigger than the other one should i have new tabs welded on or what? thanks for the help
    Pictures man, Pictures?
    • Panacea
      • Dec 2011
      • 36
      It's a crapshoot with aftermarket tanks, you may have to raise the lower mount or better yet, if you have access to a welder, extend the tabs on the tanks with a couple washers to get them down that last half inch...
