2 questions how many in 50 and what carb
  • Glenn
    Member to Remember
    • May 2007
    • 403
    I have a 1950 Pan FL 65XX and am trying to find out how many pans were made in 1950
    which leads to my question of what carb should be on my bike
    mine was a barn find not touched since 1964 and has a m36 on it now
    Moose
    aka Glenn
    Published factory production numbers say there were;
    ES 1268
    EL 2046
    FS 544
    FL 7407
    total 10265
    The M36 was used on the early 61" engines in 1950. Later 1950 61"s used a M61. When is early and late? If you subtract 1000 from your serial number your 55XX seems to be about in the middle.
    • Glenn
      Member to Remember
      • May 2007
      • 403
      Thanks Chris
      which carb would be for the 1950 FL 74" with the 65XX ser. number
      Moose
      aka Glenn
      • Sargehere
        Member since 1972
        • Jul 2006
        • 971
        That would be an M74, Glenn. Tricky, how they numbered um, eh?
        Gerry Lyons #607
        http://www.37ul.com/
          Once again the 1950 F models are a split year. They started out with a M45 and sometime during the year switched to a M74. The M74 is listed as "Late-1950-Early 1951 F and FL. What is late and what is early? Once again you are in the middle.
          • Glenn
            Member to Remember
            • May 2007
            • 403
            think I'll start looking for a m74 I have a great condition m36 anyone want to trade
            Moose
            aka Glenn
            • tomcat1
              • 115
              Look at the bottom of the page
              AMCA 26656
              47EL
              47WL
              • Glenn
                Member to Remember
                • May 2007
                • 403
                thanks tomcat hoping someone will need a 36 and would like to trade
                Moose
                aka Glenn
                • flthead
                  • Dec 2003
                  • 412
                  any pics of this '50 as found ? post 'em if you can
                  • Glenn
                    Member to Remember
                    • May 2007
                    • 403
                    pics of the 50 with the gas tank removed they were all gummed up inside and had to be cleaned. Now the whole bike is in many pieces and being totally redone
                    this was sitting in the guys garage since 1964 covered up in the back corner when I found it only about 1 mile from my office
                    Moose
                    aka Glenn
                    • Glenn
                      Member to Remember
                      • May 2007
                      • 403
                      sorry it is a m35 guess the eyes are the second thing to go
                      Moose
                      aka Glenn
