correct finish?
  • Schorsch
    • Feb 2009
    • 91
    correct finish?
    Hi PanHead Specialists,
    i want to know the correct finish ( parkerized, cad or black paint? ) of the foot clutch and foot brake assembly for the Pan's from 1949,1950,1951 and 1952 ?
    Georg AMCA2781
    I answered that question on your first inquiry. Bob L
    Top motor mount including choke lever, washers and nuts that bolt it to the engine heads=Cad. The frame mounting bolt and related washers and nut=Parkerized
    Note: The motor mount goes right to the heads. The thick washers go on top of the bracket not under it.
    Clutch release lever (one on top of tranny?)=Parkerized
    Rear brake pedal and mounting plate (Only the spring is painted black)=Parkerized
    Clutch pedal and mounting plate (Only the spring is painted black)=Parkerized
    Note: All brake linkages and hardwareare parkerized. Clutch release rod, nut and clevis are cad.
