Removing Throttle Shaft Bushing (Linkert M35TP)
  • wideglide38
    • Jul 2008
    • 656
    I am looking for suggestions/recommendations as to the best way to remove the (2) throttle shaft bushings from a M35TP body? My throttle shaft has a little slop and I'm thinking it might leaking air (seems to be leaning out at high speed).
    It appears the bushings rest on a shoulder inside the body (meaning cannot drive the bushings through into the body) and there is no lip (between body and bushing) to set a punch pin on. I thought of using a long 5/16" tap or screw extractor! Any suggestion?
    William #10035
    William Edwards, AMCA #10035
    • 2024
    I usually carefully choose a tap and thread it in part way and then drive the tap out from the opposite side using a pin punch - never failed me yet. It will drag the bushing with it.
    Jerry
    • wideglide38
      • Jul 2008
      • 656
      Thanks Jerry. I see the key word - carefully!
        • 2044
        7 mm. tap woks best
        • wideglide38
          • Jul 2008
          • 656
          Thanks for the info!
