correct finish for parts ...
  • Schorsch
    • Feb 2009
    • 91
    Hello Experts,
    how is the correct finish by a 49 FL Panhead for the following parts:
    1. top motor mount
    2. clutch release lever
    3. rear brake pedal & bracket
    4. clutch foot lever & bracket
    parkerized, cadmium plated or black painted ?
    Georg AMCA 2781
    Top motor mount including choke lever, washers and nuts that bolt it to the engine heads=Cad. The frame mounting bolt and related washers and nut=Parkerized
    Note: The motor mount goes right to the heads. The thick washers go on top of the bracket not under it.
    Clutch release lever (one on top of tranny?)=Parkerized
    Rear brake pedal and mounting plate (Only the spring is painted black)=Parkerized
    Clutch pedal and mounting plate (Only the spring is painted black)=Parkerized
    Note: All brake linkages and hardwareare parkerized. Clutch release rod, nut and clevis are cad.
    • Schorsch
      • Feb 2009
      • 91
      Robert, thank you for your complete information - it's very helpful for me!
      Georg AMCA 2781
