Im looking for an original rear sprocket riveting tool HD part# 12067 X or a source for a reproduction.
Rear sprocket riveting tool wanted
Tags: None
I have been looking, i guess not hard enough. I would definitely pay that for the tool.Last edited by Matt McManus; 12-04-2010, 01:26 PM.
If you want the sprocket rivets to hold, not loosen and all shear eventually, leaving you stranded, just use an air hammer. Anyone in an auto body shop could do it.
Rivet Tool
You might get away with a air hammer on early drums.Originally posted by Sargehere View PostIf you want the sprocket rivets to hold, not loosen and all shear eventually, leaving you stranded, just use an air hammer. Anyone in an auto body shop could do it.
I replaced many sprockets when I was in the business.
I made adapters for my jig to do all the different drums.
If you use an air hammer on hydraulic cast drums you are looking for a cracked flange.
I had a customer that had a great time saving idea. He tried to remove a sprocket from a 67/72 thick flanged drum in a 50 ton press. I sold him a brake drum.
The secret to using the factory jig is having some skill.
The rivets you might get are to long sometimes so cut them down to about 1 & 1/2 the diameter above the sprocket
Jim
For people who are shopping, the PN 12067-42 is the one for the 45 brake drum. PN 12067-X is for Big Twins, at least through '57.Originally posted by junkyarddog View PostYou might get away with a air hammer on early drums. ...Jim
Only working on my '37, about 40 years, and an air hammer used judiciously works just fine. It's all in the touch, and common sense.
I was wondering if anyone is making a QUALITY reproduction of the 1206-X sprocket riveting tool. I used to use one years ago and with a little finness, it worked very well with either a pneumatic rivet gun or manual setting. I'm currently attempting to rivet a new sprocket onto my '47 brake drum and I'm having a heck of a time keeping the rivet heads flush to the sprockert. Also compounding the task is the fact that the drum is freshly painted. The 1206-X tool would really be the answer before I go off on some time-consuming tool-building tangent...
Thanks,Bill Pedalino
Huntington, New York
AMCA 6755
Problem solved...
I used an old sprocket turned upside down installed against the new rivet heads. I used several small C-clamps to clamp the old sprocket to the new one, thus sandwiching the new rivet heads inbetween with the old sprocket positioned between the rivet heads and the bucking bar.
I moved the c-clamps around as I progressed to keep them fairly close to the rivet in question in order to avoid any bounce while hammering the rivet down. I had to sequence rivets vs. dowels as the heads on the dowels are deeper than the those of the rivets.
The result: It took a bit of time to continually adjust the C-clamps and to manage the rivets vs the dowels, but in the end all rivets and dowels were set to full tightness against the dust ring with all heads flush against the the sprocket. I'm very pleased.
But I would still love to find that1206-X rivet arbor!Bill Pedalino
AMCA 6755
Gosh Folks,
You make it sound so hard, when a simple jig is easy to make.
If you diegrinder the anvil just right, it won't leave a ring on the heads of the rivets.
The press attachment is half of an old valve. held on with an old fork boot.
Air hammers are for taking them off, not putting them on!
....CottenAttached FilesLast edited by T. Cotten; 05-25-2014, 12:34 PM.AMCA #776
Nice setup Cotton - pretty much what I had in mind, but for the one sprocket in ten years that I change, right now it wasn't worth the time. Thanks yet again for sharing. When I have the time to enjoy doing it, I will be making a similar tool at some point.Bill Pedalino
AMCA 6755
This is one that I made. It has a step on it to rest on any bench vise. Made several different centering collars that fit over the pin, between doing this and the adjustable boss; sportsters, mech BT and both early and later hydraulic can be done on the same fixture. In the boss I have a hardened recess to accept the rivet head and note the clamp that holds the sprocket to the drum to insure a tight fit. Once you adjust the boss for the diameter drum just spin it on the center boss, the centering bosses are made with steps to adjust the height for each different drum so the boss can remain the same height.Bob Rice #6738
