knucklehead cylinders 61/74 cylinders
  • DANPATCH
    • Apr 2009
    • 313
    when did they start using thicker base cylinders.Were the 61 cylinders cut down at the top to lower the head for A shorter stroke. Is this what caused the lip at the top of the 61 cylinder.Thanks for your time
    • 2024
    Late EL and FL cylinders are totally different castings. Jerry
