Wiring terminals
  • Eric MATHIEU
    • Sep 2008
    • 70
    Wiring terminals
    I am working on my 38 EL and am down to the wiring. I'm trying to determine if the ground wire connected to the oil line should use an eyelet terminal or if it should be a "hangman's noose" dipped in solder. Chris maybe you have a high resolution factory photo of a 1938 showing how it should be (in fact I could use both sides of the bike if you have it) ?
    Thanks for any help,
    Eric
    Eric MATHIEU @ Beauty of Speed
    www.beautyofspeed.com
    I'm not sure what it is???
    • junkyarddog
      • Feb 2010
      • 193
      Chris
      You never cease to amaze me at how much effort you go to and the depth of information and photos you come up with.
      You are a major asset to the forum.
      Question: Do you have any life besides the puter world?
      Jim
      • Eric MATHIEU
        • Sep 2008
        • 70
        Chris,
        I have not been able to make out what that is for sure either. I was hoping you would have a high resolution shot that would show it. I would say it looks more like a noose than a terminal but given the small screw used to hold the wire to the clamp, it would have made more sense if the factory stuck to a terminal (the same ones that are used on the dash main switch). Anyone else have any input?
        Eric
          Originally posted by junkyarddog View Post
          Chris
          Jim
          Of course I do. I work 60-90 hours a week too.
          • ricmoran
            • Oct 2010
            • 260
            Eric, on my 39 there is a square flag type terminal that is soldered to the ground wire which is black & white cloth covered.
            • Eric MATHIEU
              • Sep 2008
              • 70
              Thanks for the info. I think flag terminals started appearing sometime late 1938. Also, isn't the ground wire on a 39 on the frame?
              • pete reeves
                • Nov 2001
                • 245
                Eric. The flag type terminal is part number 1520-39 so I would think it safe to use the twisted wire terminal on all but the very last of the of the 38s .
                Pete Reeves 860
                • 46WL
                  • Feb 2007
                  • 60
                  Eric, the ground on the frame isn't until '41.
                  • ricmoran
                    • Oct 2010
                    • 260
                    Eric,
                    On the frame are 2 wires on each side of the seat post, these are hot leads.
                    Rich
                      The one on the right goes to battery pos and the one one the left goes to tail light running. Yup, I'd say there hot. Bob
                      • Eric MATHIEU
                        • Sep 2008
                        • 70
                        Peter, what type of terminal would you say is correct for the ground wire on the oil line then? The choice bieng either twisted like all other wires or with a small terminal like the ones used on the dash main switch?
                        Eric
                        • ricmoran
                          • Oct 2010
                          • 260
                          Eric, a picture is worth a thousand words. Even if it is slightly out of focus.
                          Rich Moran
                          AMCA Member 18043
                          Eric
                            Rich Moran
                            AMCA Member 18043
                            Good picture. But that is not what was used on the 1939s.
                            • ricmoran
                              • Oct 2010
                              • 260
                              Thanks for your advice, fotunately this is not in AMCA shows but for street riding. Luck is onmy side with no events/shows being in Hawaii!!
                              That means along with trying to find the correct frame that has not been butchered for this bike I'll have to find the correct harness too.
                              Another one of lifes ambitions that may or may not be met!
                              Rich Moran
                              AMCA #18043
