motor mount damage
  • motor mount damage
    Where is the best place to send knuckle cases for extensive motormount repair? Has anyone had great service? jeff
    case repairs
    Where are you located? If you are in the east or close to the east I can recommend Arno St. Denis @ 301779-0438 in Maryland or Paul Feibus at American Cycle Fabrication 570-752-8715 in Penn. Both do excellent work! I'm sure there are others out there but these two I can vouch for.
    Tom ( Rollo) Hardy
    AMCA # 12766
      I have used Tom Shaw at Creekside Welding in Illinois. He advertises in the club mag, also on the web at www.creeksidemc.com
      Not to say that the others are not as good, but he as welded on 2 knuck cases for me, one badly damaged and repaired nicely.
      FYI, there is a nice article on Paul Friebus and his land speed record flatheads in the latest issue of Iron Horse magazine.
      Lonnie Campbell #9908
      South Cackalackey, U.S. of A.
        Thanks guys for the referrals. Jeff
          I had Don Sullivan at Headhog fix my 51 front motor mounts, both were cracked off thru the center of the bolt holes. The rear mount was also damaged and the generator cradle was completely gone. When Don was thru, I couldn't tell they had been repaired. He is an artist...Mike
