40 E vin and production #'s
  • bjk47
    • Feb 2006
    • 28
    I am curious to know if there are knuckles with a 40 E #### VIN and would they also have 40 E #### production numbers. I have heard that 40 E's were special factory police bikes. I have seen a set of cases with these numbers on them and the correct casting dates of
    A 0 inside both right and left side cases. so what"s the poop? thanks
    BJK47
    • 2024
    Yes to both questions but a visual (picture) would be better.
    Jerry
    • bjk47
      • Feb 2006
      • 28
      thanks. i will try to get pics
      BJK47
      • bjk47
        • Feb 2006
        • 28
        any idea how many were produced?
        BJK47
        • flat-happy
          • May 2009
          • 543
          1940 E were 176 units but they were all sidecar equipped (ES) there were 3,893 EL's that year
            Special, no. Low compression, yes. E was low compression and EL was high compression. Nothing special.
            • bjk47
              • Feb 2006
              • 28
              thanks a bunch. but why did they put the E in the line bore/prod. #'s instead of the usual -? i have not seen another motor with a letter after the year number in the belly numbers.?
              BJK47
              • flat-happy
                • May 2009
                • 543
                post a picture of them and maybe we can guess better
                  Here's a '40 EL producton number.
                    70 years after the fact you ask us why the MoCo did something? I dunno why, that is just the way it was done in 1940.
                    The 1940 model was a stepping stone. The small port heads were replaced by the large port. Four bolt carburetors replaced the three bolt. All in preparedness for the forthcoming 74" engine in 1941. 16" wheels became an option.
                    • jwl
                      • Dec 2001
                      • 338
                      I think the numbering system may have had something to do with the anticipation of the F series being introduced with the 41 model year. The first 41's would have to have had 40 linebore numbers so there had to be some way of keeping the E's and F's separate. I'm not sure when the first 41 was actually produced though. At some point the moco ultimately kept them separate by stamping the F's with a 7 by the rear engine mount holes. But like Chris stated, who can really know for sure what they were thinking or doing 70 years ago.
                      • bjk47
                        • Feb 2006
                        • 28
                        40 E
                        thank you all. the picture is exactly like on the 40 cases. i appreciate all the info. i am helping a friend to restore his 40 E back to original specs. where is a good place to buy cylinder sleeves? BJ
                        BJK47
                        • bjk47
                          • Feb 2006
                          • 28
                          40 E
                          thank you all for the info. I am helping a member to restore his 40E motor back to original specs. the pic is exactly like it is on his cases. BJ
                          BJK47
                            Knucklehead cylinders are not good candidates for sleeving. Over the years I have seen them crack completely around the cylinder and the top half starts rising.
                            However if you must sleeve this is the place. http://www.lasleeve.com/master.html
                            • bjk47
                              • Feb 2006
                              • 28
                              40 E
                              thank you all
                              BJK47
