1939 EL Knucklehead gas tank info
  • Rod E
    Rod E
    • Jul 2009
    • 15
    Hi, I have a 39 which I started to rebuild from a basket in 1982. Did all the work myself. Since then I have heard conflicting information on my gas tank, it has what appears to be a 1940 with the shut off on top. But the original owners son I bought it from claims that was the way his dad bought it new in 39. He had bought a 1938 also after the war for a parts bike and by the time I got the bike they only saved the best parts in boxes around mid 60's. And some of them where in bad shape. This was the tank that they had, it had no holes in the side for badges or anything on it when I repainted it. My engine Number is 39EL3528 which is a high number and I was hoping some one might have a number higher then mine and let me know if their tank is the same as Willie G once told me at a show they sometimes ran out of parts towards the end or a run back then, and would use what they had available. Any comments?
    • 2024
    About 10 years ago I restored 39EL50xx for the nephew of the original owner and it had the accepted tanks for 1939. The odd thing about this bike is that it had a 40 and up oil tank and one wheel hub was of the 40 to 43 variety. The only evidence that this bike had ever been apart was that the sheet metal had been painted metal flake red in the 60's by the guys dad - original owners brother. The motor and tranny had never been apart or out of the chassis. I am almost convinced that it could have come that way.
    Jerry
      Do you think that the MoCo waited until the last moment of a production year to make changes in parts that were not new features? Oil tanks and hub modifications are not new features.
      Note that the factory photos of the 1938 are prototype photos of a bike that is actually an older 1938, 38EL3072 to be exact. Most all of the 1939's used the seamed oil tank.
      • LJH
        • 61
        I have seen, 4 late year 39s in the last 15 years,
        with the 1940 and up oil tank, and a vented transmission case
        with the non vented kicker cover. I believe, these were late year changes
        they were barn type, unrestored bikes, they all had the correct tanks.
        Regards Lee
          • 2024
          Chris I understand that as well as anybody but if that bike had showed up to be judged you'd have been the first guy to gig it. I remember a very original high numbered 1936 EL 20 years ago that was restored by Jim McClean that had the later (early 37) type frame - you and others were absolutely adament that those frames never came in 1936 so he found an early frame and restored the bike with it instead. That bike had karma and was so original (except for paint) you could taste it. However recently I see you have almost admitted that such a bike could exist - especially since a couple more like it have since been discovered. I thought that you did the guy and the bike a disservice then and I still think that today.
          If anybody has an overly rigid concept of what a given bike should be it is you and not me - so no lectures.
          Jerry
            • 2024
            Lee
            I agree on the transmission vent. I've believed for years that it moved in mid to late 1939 production. The first cases that you see with the vent actually have no casting boss like later. They machined a recess and tapped it. I'll post a picture of it later.
            We've actually seen one 39 UL with a vent in the tranny and also one in the cover. Must have been right at the change.
            Jerry
            • George Greer
              • Jul 2007
              • 151
              Not butting in here,
              But Jerry Wieland,
              No response from you here nor at the other boards that we both frequent concerning my questions.
              Respectfully George
              George Greer
              AMCA # 3370
                [QUOTE=Jerry Wieland;84639]Chris I understand that as well as anybody but if that bike had showed up to be judged you'd have been the first guy to gig it. I remember a very original high numbered 1936 EL 20 years ago that was restored by Jim McClean that had the later (early 37) type frame - you and others were absolutely adament that those frames never came in 1936 so he found an early frame and restored the bike with it instead.
                Well Jerry,
                I have to differ with you on that one. First of all I never judged anything twenty years ago. I also know that the "Lightning" frame,along with a lot of other '36EL parts, did not last thru production. So don't be spouting things telling me what I would or would not do. When it comes to what I would or would not do you do not know what you are talking about.
                • Rod E
                  Rod E
                  • Jul 2009
                  • 15
                  I am sorry. Everyone so far has used my Gas Tank question to talk about their problems. Guess this was not the place to ask my question, and will refrain in doing so in the future. Thanks to Jerry for the first reply about not having all "1939" parts on the bike he restored. I would still like to hear from some one who has a 1939 with a higher serial number as to the type of GAS TANK he or she has. I would never think about having my bike judged as I know it has a few 1938 parts on it and and a couple of reproduction parts that would not meet the muster of this club. I did the best I could with what I had and that's what counts for me. Will try not to ask anymore questions. Thanks
                    • 6034
                    Don't do that Rod. I've spent my whole life asking inflammatory questions. . . Especially here. People are passionalte about this hobby and I think that is a good thing because we increase our knowledge about this stuff. I remember when I first got into this hobby and the shallow puddle of knowledge that existed in rags like Easyrider. I would venture to say that today, more is known than ever before about the broad spectrum of American motorcycles and it's because there is this passionate thirst for knowledge and facts. Remarkable information has been exposed here on the AMCA forum.
                      • 4790
                      ROD E,
                      I agree with Exeric, don't let the bickering put you off, it isn't about you for sure. You have put together a beautiful machine and should be proud of it. I would say that your tank is wrong. Your bike is not a very high serial #, only about the middle of production and would have been built to the norm. The fuel shutoff plunger was a new feature for '40 and touted in the advertising so it is unlikely that any, even the very last, '39 models would have had it. It could have been changed early on by an owner wanted the latest and greatest feature. You can always look for some '39 tanks and change them out at a later date, or just enjoy it as is. Don't let a personal feud get in your way! Those two are always at it!
                      Robbie
                        Years ago I was called to look at a 1936 EL that had just been purchased from the original owners family. They told the buyer that it was all original and nothing had been changed. Upon seeing the bike for the first time it was obviously a very old repaint. Then I could see that the frame, fork, handlebars, and front fender were 1941 era items. The new owner questioned the family if the bike had ever been wrecked. One person remembered it had been in a small acident just before WWII. Obviously the dealer ordered a new frame, fork, handlebars, and fender to do the repairs. It still retained the 1936 front brake. Every other part of the bike was 1936 stuff.
                        So the bottom line is that if you buy a bike from a family member they may not know the correct history of the machine. Not to mention that Harley riders always wanted the newest things on their bikes and upgrading was common. So unless you are going to restore all the original parts to the bike I would ride it and enjoy it and not sweat the small stuff. Pick up parts you believe to be correct and swap them out as you can.
                          • 2024
                          Rod
                          Sorry Rod but I guess I am the one kinda responsible for the distraction because it first started in my post. My personal opinion is that there is no way that your bike which is at least 1500 units from the end of 1939 production would ever have come with a 1940 and newer type tank. If that were the case there would 39 EL's all over with the same situation.
                          Jerry
                          • flat-happy
                            • May 2009
                            • 543
                            a little food for thought----is there any chance some machines sold to dealers or executives for their personal ride could have been fitted with the 40 tank? i think it might be possible as a special order?? they had to exist during the 39 model run. surely they didn't wait until october 1939 to start manufacturing them. several situations have proven that things were pretty relaxed as for as rules and regulations are concerned especially before WWII. they have dealer shows now where only the dealers are allowed in to view all the new models and accessories. when i worked at the dealership from 95-98 that show was usually in june and the owner would come back and tell us all about it and show us pictures etc. it was never open to the public and dealers could only bring 2-3 employees with them. of course not being an ass kisser i never got to go---but i'm not bitter!!!
                              • 4790
                              In the old days the dealer shows were in September. Well documented in the Enthusiast. Back then as in later years the production line shut down for a month to change over to new models. During that time tooling was changed, parts were stockpiled, sheetmetal formed, etc to be ready for the new models. That month has changed over the years as all things have, to get a head start on the new models. When I attended the dealer show in '79 it was in August for the new '80 models. Previous to the shutdown bikes were updated with runnibg changes but not items considered NEW features. I don't believe there is any way a '39 model was ever equipped with a '40 tank. Reading the Enthusiast most dealers got their Demo models in October although some did not get them until Dec. or Jan. of the following year. And numbers were tied closely to orders in hand, the machines were not built on speculation. Priority dealers got theirs first, small dealers and "Associate " dealers last. Just good business in those days. Running changes were generally done on items with a history of failure, not cosmetics or new features.
                              Robbie
