Is there a proper sequence for the installation of stock exhaust pipes and muffler for a 47 FL? Haven't done it before and I want to know what to look out for also, for sealing: Permatex Ultra Copper, or maybe Permatex Muffler & Tailpipe sealer? Just looking for some good tips... Thanks, Bones
Installing exhaust pipes/muffler...
47 knuckle
I am lucky to have a good knuckle that had shot gun exhaust i now have the correct original exhaust @ would like to get the correct spots for the clamps andhow they face on the pipes i would also like to buy the correct crash bars buddy seat thanks art
Get your self a 12 pack and a bible. Your going to need it! Bob LOriginally posted by BONES47FL View PostIs there a proper sequence for the installation of stock exhaust pipes and muffler for a 47 FL? Haven't done it before and I want to know what to look out for also, for sealing: Permatex Ultra Copper, or maybe Permatex Muffler & Tailpipe sealer? Just looking for some good tips... Thanks, Bones
I did one last winter on a '46 EL.
As I recall... Front cylinder down pipe. Then flat pipe. Rear pipe. T-pipe. Then muffler. You will want to test fit all the clamps. I bought my system from AAOK and I thought it was very good. I did need to do a bit of tweaking, but not much. I prefit everything, especially the clamps to make sure that it goes together without stressing your cylinders. It is very important that you don't stress the exhaust ports as that can break the brittle cast iron.
Before final installation, I beaded all the pipes and then painted with Black Velvet exhaust finish from POR-15. I generally despise POR-15. But they make good exhaust paint that I am very happy with. After installation, I painted the system again as a unit. Brushed. All the joints were sealed with Acousti-Seal, which does a great job until carbon plugs up the slip joints. Don't use Permatex copper. It's not the right stuff. Acousti-Seal is specifically for exhaust joints.
I may have some pictures from the installation and I will post in a minute if I still have them. As Bob L. says... it's a bit time consuming. It took me most of a day to get the system on right. Then time for the paint to dry and final assembly takes a good half-day to finish. But it ultimately does work. Just don't stress things!
Cheers,
Sirhr
IMG_0079.jpgOriginally posted by sirhrmechanic View Postsome pictures from the installation
front header pipe clamps
would someone please tell me if I have these clamps correctly arranged. I can't seem to get the clamp on the header pipe to keep from rubbing on the generator holding strap. the pipe is OEM so it should have the correct radius bend. it's an early 61" motor and frame.
unless these are correct, if i could get a photo of the correct arrangement, i would greatly appreciate it. thanks!Attached FilesLast edited by rustynuts; 02-03-2012, 03:09 PM.
This is the correct way.
I believe your clamp on the frame is on backwards.Originally posted by rustynuts View Postthanks Chris- but i'm sorry, i still can't tell how the clamps are positioned. which way are they facing. how do they clamp together at the bolt. do they both fully close or are the clamp tabs interlaced.
do i have it right in the photo i posted???Be sure to visit;
still struggling
i have been struggling with these clamps all weekend.
still not resolved. could someone please throw me a line here. i would like to move on with my project. i think 3 full days devoted to two little clamps is long enough- don't you.
Rustynuts,
I'm also struggling with the same problem. I think, (but could be wrong), that the clamps you have & what most people use because of availability & the type that are repopped, are actually 45 flathead. Someone with definite knowledge hopefully will join in. I remember seeing in Palmer's book Big Twin front header pipe clamps having the tabs bent perpendicular to the center of the round openings. The 45 clamps have the tabs tangent to the circle. Does that make sense? I made clamps for my EL, but I'm unable to position them at the top of the sidecar loop casting as they should be. Mine fit much further up the down tube. My header pipe is repop, I plan on replacing my pipes with more accurate repops hoping that it might correct this clamp issue. Hope this helps.Bob
Hi Rusty.
I recently fitted a aftermarket exhaust to my 1937 Knuckle. And some of the issues that I had to cure along the way as follows:
Front exhaust header nedded a 1/2" wide X 1/8" deep depression knocked in it "about 1" long, running along the side of the header" to clear the case stud and nut. If you dont put this in, it will be impossible to move the header around while try to mate it with the squish pipe. If you dont put the depression in the header it will put stress on the exhaust spigot and could start a crack. Your exhaust header should fit into the exhaust spigot with no stress load.
I spent 5 hours fitting/modifying the front header and clamps alone. The header clamps that were supplied with my kit were 1941-47.
I had to put the clamps in the vise and put a shifter on the clamp ends and put a little twist on the ends.
When I was tightening the header clamps to the header I had a little nylon hammer that I would lightly tap the clamps then tighten the nuts and tap it again etc etc. This method stops the clamps from pinching on the header and pulling it in a direction, other than stress free.
I gave up on the squish pipe that was supplied and used an original.
The rear pipe was one of the Olsens make and it need no alteration.
The last alteration probably wont affect you as I had one of the aftermarket fish tail mufflers.
When my muffler/Y pipe was fitted to the squish pipe it hit one of the trans kicker cover studs and forced the muffler sit with the fish tail rolled out at an angle to the bike. I think the Y fitting for the muffler was fitted at the wrong place. I had to make a 1/4" deep depression along the side of the Y pipe so that the muffler could roll back to the correct look and also so the transmission case could go through its full adjustment for the primary chain.
Also had to port out the hole in the Y pipe with a die grinder for the gas from the rear cylinder to enter the muffler. It was rough oxy cut to only 3/4" diam.
I have read the complaints and struggles of people trying to fit reproduction exhaust systems on this site and others, and now have a real appreciation for thier efforts.
I got mine to fit but it required a great deal of thought and effort.
Your picture of the brackets is clear. I do not know the manufacturer of your clamps but my system came with 41-47 clamps. The only way I could get them to fit was to have the flat backs of the brackets, facing to the front of the motorcycle....and then twist the ends to meet each other. I had the bolt facing inward and put a small spacer between the nut so that I could get onto it for tightening.
I have since purchased a set of early style clamps to make it look right, and I relish the thought of fitting them with the ease and hassle free style that I am foolishly hoping for.
Regards Steve.Steve Little
Upper Yarra Valley. Victoria.
Australia.
AMCA member 1950
The last one I did was a '46 knuck with Teds exhaust parts .I'm used to modifying this stuff.It took about 3 hours to do the complete install. I was very happy with the end fit,it came back off and on easily cosidering that the pipes were flat on the ends from manufacturing and shipping.
Mine took the better part of a day, but the AAOK system pretty much dropped into place.
That said, a lot of the exhausts we put on cars need some bending or tweaking. You may have to do some bending... do you have access to a press? Doing some radiusing may be needed. Sometimes it's as simple as putting a fat dowel in each end of a pipe and spreading them a bit. Sometimes a 20 ton press can be used to 'spread' a bend just a fraction. It usually doesn't take much.
Don't assume that a new system is bent perfectly!
Also, where is your engine positioned in the frame? Does it need shimming? Are the mounts the right height, etc? If the engine is off, the exhaust won't fit.
We have a saying in the old car world: Parts that 'almost' fit.
Cheers,
Sirhr
