Fuel reserve
  • PaulV
    • Nov 2004
    • 13
    Fuel reserve
    I have a fuel shut off rod in my 47 knuckle, 3 1/2 gallon tanks, that only gives me 4-5 miles of reserve fuel. The rod I have has a hole near the bottom of the rod, and 2 holes about half way up the rod. I understand that there is a rod for 45" tanks that has the 2 holes much farther down on the rod, and if used in 3 1/2 gallon tanks gives even less reserve.
    Some one sent me a picture of the 2 different rods a while ago. I definitely have the one with the holes higher up on the rod.
    Can someone explain to me how the reserve system works. (why 1 hole at the bottom, why 2 holes higher up on the rod?) I have looked at it and it looks to me that even if I don't pull the rod up, all the fuel is going thru the valve, anyway. I don't understand how the valve gives additional fuel.
    It does shut off the fuel when I turn it closed. Is there some other "adjustment" that I am not doing?
    Paul
