1947 tail lamp
  • starhub
    • Dec 2005
    • 42
    1947 tail lamp
    Hi, I am in the process of restoring my '47 EL. I know that the tail lamp should be the early version with the license plate bracket held on with screws. However, I have seen two versions of this lamp. One has GUIDE R-H5 stamped just below the license plate bracket. Anyone know which one is correct?
  • Snakeoil
    • Jan 2008
    • 219
    I have a late model year 47 EL with an engine number in the 12000 range that is bone stock. I have close up photos of the tailight and the license bracket that I can send you if you PM me with an email address. Files are high res pics and too big to post here.
    To answer your question, my tailight housing is stamped GUIDE R-H5. License bracket is held on with two straight slot flathead screws with steel locknuts. If this is the late version, then you might surmise that the other is the early version.
    Regards,
    Rob Sigond
    AMCA # 1811
    • Paps
      • Jun 2003
      • 1814
      Since 47 is the topic....anyone got an original solo seat for one ? Paps
      • oldsouthmcy
        • Jan 2009
        • 51
        Starhub,
        The first production 1947-1954 tail light has the screwed on bracket and is marked GUIDE R-H5 on the body just below license bracket (wording facing rearward on the motorcycle) . All of 1947 to mid/late 1948 use this lamp .
        The second production 1947-1954 tail light has the screwed on bracket and is marked GUIDE R-H5 on the license bracket (wording facing forward on the motorcycle) and not marked on the body. Mid/late 1948 use this lamp.
        The third production 1947-1954 tail light has the riveted on bracket and is marked GUIDE R-H5 on the license bracket (wording facing forward on the motorcycle) and not marked on the body. 1949-1957 use this lamp.
        Another distinguishing factor, since rivets can be removed, the hole widths are different between lamp bodys with screwed on brackets and riveted on brackets. The hole distance, center-to-center, is 1-3/32" on 1947-1948 lamp bodies. The hole distance, center-to-center, is 27/32" on 1949-1954 lamp bodies.
        Sorry Paps, no seat.
        Bruce Palmer III
        AMCA #667
        How to Restore Your Harley-Davidson
        How to Restore Your Military Harley-Davidson
        • oldsouthmcy
          • Jan 2009
          • 51
          Starhub,
          Bruce Palmer III
          AMCA #667
          • starhub
            • Dec 2005
            • 42
            Thanks oldsouthmcy for the info. I really appreciate it.
            Thanks, starhub
            • D.Mac
              • Feb 2007
              • 240
              1950 "tombstone"
              [QUOTE=oldsouthmcy;75802]
              Does anyone have a good close-up pic or two that shows the rivits holding the license bracket, especially the rear view?
              Thanks, Doug.
              Doug McLaughlin #6607
              NorCal, USA
              • bmh
                • Feb 2007
                • 901
                Here's front and rear. not from same bike though. Rear is from a later 49 and the front with the AMCA badge is an early 52.
                Brian Howard AMCA#5866
                  • 6034
                  That's the hard lens to find. That blue dot made it about worthless.
                  • D.Mac
                    • Feb 2007
                    • 240
                    Rivits
                    Thanks Brian,
                    Thats just what I needed to see so I can make sure to use the right rivits.
                    Doug.
                    NorCal, USA
                      Be VERY careful riviting on that pot metal tail lamp body.
                      • bmh
                        • Feb 2007
                        • 901
                        I actually prefer Blue dots. I think they offer a margin of safety by getting drivers attention. They do make the lens more fragile, and most agree with Eric on the subject so they are usually a little less expensive. Although you are probably much better off these days buying a repop lens from Old Dude as that is what most people are pawning off as NOS anyway, your local optometrist should be able to polish off the "GUIDEX" script without any trouble ( now you know where all those NOS lenses on E-pay are being found). As for the rivets, Old Dude has them. One other thing I happened to think of, I believe the license plate strap was also marked " GUIDE RH-5" though it can't be seen in the pics.
                          • 6034
                          I didn't mean to sound so cynical about it Brian. Everyone has their own tastes and that should be respected. I am always looking for the lens without the Guidex branding so it's bitter to see one that has been altered. Chris makes a good point about using care in riveting the license brkt. to pot metal. I have 2, otherwise beautiful tail lights that are broken there. . . . Hey ! I didn't do it.
                          • Steve Little
                            • Apr 2008
                            • 915
                            Hi. I have a couple of the 3rd type "riveted" models but the outside rivet heads on one of them is larger. They both have the number plate bracket with Guide R-H5 facing the fender and the rivet heads on both tail lights are the same on this side.
                            But the heads of the rivets directly above the clear licence plate lense are bigger on one of them.
                            One of mine looks like the one that bmh posted and the other has almost the same larger size rivet head back and front. It doesnt look like tinkering by some handyman.
                            Steve Little
                            Upper Yarra Valley. Victoria.
                            Australia.
                            AMCA member 1950
                              Eric I have the tenance to beleave that might be a factory accserory. If the guy back then took the time to bore that lens with a dimond bit god bless him. Get real it's a fake. Bob
